scjakester
- Aug 26, 2007
- 57
I started spring cleaning on my 40hp 4 stroke Yamaha last night and when I drained the foot I found water in the gear oil. Dangit! I pulled the lower unit to replace the impeller and I think its coming in through the upper seal (the one directly beneath the water pump). When you rotate the shaft you can see it bubbling up. Is this something I can DIY by just popping them in and out or do I need some sort of specialized tools or equipment to do it?
-Jake
Lexington, SC
-Jake
Lexington, SC
