Hi
I think im loosing my mind. I can not find where the pos battery cable goes on the motor. All of the areas it should go does not seam to have enough threads to add the pos terminal end. I have the manual on cd but the pics suck. To operate the power tilt and trim from the control box do you have to add extra cables from the control box other than the main engine connection cable. The tilt trim cables are not pluged into anything. they just come out under the powerhead. EDIT .I suck at wiring.
Thank You
Charles Cobb EDIT.
Thank You
Charles Cobb EDIT.
