The motor goes in and out of gear ok so I don't think that the shaft is corroded. The problem is I have too use alot of force on the shifter to get it to function. I disconnected the cable from the motor and it is very smooth but I can't shift gears buy using the motor linkage with my hand.
It seems like the shift rod is binding up and won't rotate. It this possible or could it be in the lower unit? I don't have time to drop the lower for a week and would like some advice. Thanks
