Tony Weber
- Jan 13, 2012
- 3
Hi I am new to this site and have seen many very good posts.
I have just fitted two Yamaha 115 Fs to my sea truck which is a 24 foot twin tunnel river boat. I am having difficulty getting the trim to work for both motors from the control. The individual trims both front and rear work fine. Can anyone help with a diagram. I would also like to confirm that the wiring of the gauges is correct - all seams to work fine.
The port motor while starting and running fine will not shut down without removing the battery terminal. The is a loose whit wire in the engine compartment which I believe has something to do with this?
Any help will be most appreciated.
