I have a 1984 suzuki dt 50 the boat sat up for like 4 years before i bought it from my uncle and he was having the same trouble. 2 repair shops looked at the motor and couldn't figure out what was wrong. What its doing is... it will start fine and idle fine when I put it in gear and give it a little gas it wraps up to full throttle and will not return to normal idle, the key will not shut it down nor the emergancy switch. the only way i got it to stop was pulling the fuel lines and let it run out of gas. After it did that to me one time i decided to try my luck with a suzuki dealer, with no luck they told me that it was the carbs needed to be rebuilt and the kill swith was bad, quoted me like $1400.00 for the repairs. that sounded a little steap to rebuild 2 carbs. I decided that if thats all it was i could do it myself. I took apart the carbs to find that thay just needed to be cleaned really well. while i had the carbs off i went ahead and replaced all the gaskits back to the crank case. i guess my question is if the carbs, throttle linkage, fuel pump and gaskets are all clean and or new and working properly, what could i be? Keep in mind that iI just put the gaskets on tonight so I haven't got a chance to try it yet. I replaced the gasket at the advice of a different shop. that guy seemed to think I had an air leak at the crank case . would that make it run away and not shut down?
3 Shops, 5 mechanics, no real answers except the one guy that told me to come get my boat out of his shop and dont ever bring another suzuki back in there. So far all I've been doing is paying diagnostic fees and cant get any help.
hope someone out there has the answer
