i have a 02 suzuki df140 with a steering problem that I have been fighting for a few years. It just does not swing that easy when I disconnect it from the steering. I had teleflex and thought hyd steering would power through it but its still a bit stiff. I think I need to pull the engine and remove the steering swivel bracket (have also seen it referred to as king pin) and lubricate it. I cannot get any grease into the zirk fitting anymore.
has anyone done this? I think I can disconnect linkage and cables to the motor then disconnect the the upper and lower engine mounts and swing the eng off (with a hoist of course) then pull the pin out to lube it...this time with triple guard grease.
thoughts?
thoughts?
