liquid assets
- Dec 21, 2011
- 6
I just purchased an 88 or 89 25 hp suzuki...$ 200.00 the motor is running hot so I changed the thermostat for it was ejecting water from the p-hole. after changing the thermostat it would not eject water out the p-hole much and got too hot to touch in 2-3 minutes in a barrel of water (turned off immediatly). My next attempt is to replace the impeller (purchased the entire kit) On the port side of the motor there is a plate about 6"-8" long and about 4" wide with numerous bolts broken off flush with the plate, (there are about 12 bolts and 6 are broke) it does not blow air nor water from the gasket area where the bolts are broke off? what is behind this area?? questions at hand.
2. If I do should I heat them with a small hand held torch or heat around the bolt where it goes into the motor?
3. The prop has a very slight wobble that is not making you able to feel when running, should I leave that the way it is until it blows the seal behind the prop?
4. It has a sticker on the side of the cowling by the gas line that reads 100:1 ratio, that seems pretty weak, the little that I have run this I have used a 50:1 will this hurt/affect the motor?
this is the first time I have posted on this site, hope I am clear enough on my questions, thanks in advance!
