Hi All
I have recently purchased a second hand boat with a Yamaha 40 Hp 2 Stroke 2000 model on it. It is manual start and manual trim.
I have a couple of questions maybe some of you could help. The first one might be pretty dumb but hopefully there is a simple answer.
1. When I start the engine in the water a strong stream of water comes out of the tell tail very quickly. When I wash the motor out at home I cover the water inlet with water in a bucket but the water does not get drawn up into the motor. Also if I cover the outlet with the ear muff type hose connection and have the hose on full, it takes ages for the water to come and it is a really weak stream.
Does anyone know what I'm doing wrong?
2. I was thinking about upgrading to electric start. I bought a seconhand starter motor and solenoid from a '97 model, I'm going to get a geared flywheel and then try and install it. From looking at the motor all the holes are threre to mount the starter motor so I don't think it should be too hard. I recon the hardest thing will be the electrics.
Has anyone done this conversion and how did it go? Any wisdom to be passed down?
Thanks in advance
Sam
Thanks in advance
Sam
