Re: 1999 Suzuki DF70 code 32
Well, folks it seems I found the problem with that code 32. Just under the map sensor the hose was torn, snipped end of vacuun hose off at the point and reinstalled; no more flashing check engine light! The only problem now is that there is 1 beep about 10 to 15 secends or so and the darn thing has trouble idling/stalling and it also has a flat spot when you accelarate the throttle. Any ideas on this matter? Thanks
