The motor has been running great and has been starting In no time. I recently filled up new gas running it 50:1. After the first few runs the motor started doing something I have never seen it do. When trying to start it (manually) it appears that gas is leaking out near the prop and dripping down the skeg. This doesn't seem normal to me. I know that if it is running rich that some of the oil won't burn up completely and drip, but this is excessive. And I don't believe it's just oil, there is gas in it as well. It looks like it is coming out from the prop housing where it goes into the lower unit, then running down the skeg. Any ideas?? Thanks for the help.
