chris bayou
- Nov 30, 2011
- 2
my motor has no output from the cdi (#2 cylinder) at cranking speed or up to 2500 rpm it never kicks in .... i know this particular model runs on cyl.1&3 at idle then #2 picks up spark past 1450rpm. so far I checked coils and they are all good , checked crank position sender its dva is in spec, lighting coil ok, charging coil ok , I noticed the pulser coil only putting out 2.5v when it should be putting out 7v at cranking speed and when disconnected . could this be my smoking gun ? trying to hunt this weekend any help asap please!!!
