This engine has cylinder cover bolts (short bolts 6)that also secure to the head and then whole head is secured to the block by larger longer bolts.
Book states ..short bolts 2.9 ft. lbs. then 5.8 ft. lbs. Longer bolts 11 ft. lbs. then 22 ft. lbs...
Cylinder cover states(embossed) M6 0.8 KGM and M8 2.8 KGM..
Im looking find out how to convert metric to standard and compare.
If you have info on this torquing the cylinder heads it would be appreciated.
