jbowden3067
- Sep 2, 2005
- 14
Had the carbs cleaned and reset. Rebuilt fuel pump. When the bulb is pumped full, runs ok. As fuel goes out of the bulb engine acts like it is starved and begins cutting out even backfiring at one point then shuts off. I pump the bulb back up. starts runs till the fuel goes down. If I pump the bulb will continue to run. Would welcome suggestions. Thanks in advance
