brandomako238
- Nov 10, 2011
- 3
Oil level is good, primer bulb is primed, motor cranks but wont fire. Sprayed some ether in the trottle body and nothing. I disconnected the kill switch to eliminate that factor and still wont start, removed a plug wire inserted another plug and had my 6year old crank and no spark. (rested plug against block) Removed power pack cover and traced power wire and fuses are good. Disconnected the butt connector on the power wire and when i re-pluged fuel pumped kicked on to prime. Voltage at battery is 12.6. During cranking it dropped to 11.1 and at the starter is 10.2 while cranking. Is there a separate power supply from the ignition to the coil. I guess i will play around and probe that. I tried starting the motor by jumping it off a car battery direct to the factory cables. It still wont start and no spark. I have brand new marine grade 1/0 cable from batteries to power post which is about 10'. I tried jumping it off the car because I wanted to eliminate the circuit from the power post to the battery. I feel convinced it's in the motor and or ignition switch at the key but I have no clue where to go from here. I traced all wires coming from harness from motor to ignition switch and everything looks fine.
