JSMoore
- Sep 5, 2010
- 110
A friend of mine has a 1997 Suzuki 150 HP EFI V6 outboard on the the back of a 21 ft. center console boat. The motor has been giving us a couple of problems. And, since there is no Suzuki mechanic any where around here, we are trying to figure out some of this on our own. Any advice or ideas anyone cares to contribute will be appreciated.
Here's the two problems:
1. Rough idle - won't idle very long without quitting. Won't hold idle in gear for very long without dieing.
2. At speed, motor develops good power and runs smooth with WOT in the mid 4k rpm area. But, will occasionally "drop" a cylinder for a while. Then, it will pick back up on all 6. It does this in a completely unpredictable, random way.
Plugs have been changed. When checked, plugs look light tan - no oil, carbon or build up.
Fresh fuel, several times weekly. (boat is used A LOT!)
Replaced water separating fuel filter.
No issues with oil pump.
Runs on Hi-test auto gas, (no ethanol free gas convenient to our area)
Motor is used so much, we don't bother with fuel treatments.
Any suggestions where to look?
Thanks!
JSMoore
Thanks!
JSMoore
