Power trim fluid for F150
ccm14
Hello,
I have a 2006 Yamaha F150 that the power trim is making a strange noise. Only happens when the motor is moving forward and I am timing the motor down. Someone on this forum had said the noise could be caused by the trim fluid being low. My owners manual does not address how to add fluid or what type of fluid to use. Can someone walk me through how to check the fluid level and how much I should add? Also, what type of fluid should I use?
Thanks in advance for your advice.
Charlie
