Re: 115 v4 yamaha no spark 1&3 cyl but both ignition coils are good?
rev limit shouldn't kick in during cranking, in any case,retarded timing wont cause a no spark. Didn't know that you had the O/I disconnected. Just for S&G, remove the float sensor from the tank and plug it back into the harness and position it upside down in the lower cowling and retest. 1&3 are on the same pulser coil, which sends the signal to the cdi to fire both coils at the same time. ohm the 2-4 pulser and compare readings to the 1-3 pulser.They should be close. My later model tune up guide says 320 ohms,but as long as they are close to the same,pulsers are probably ok. I'm digging out some older manuals and will have more info later today.
