Im having an issue after running at wot. The motor runs fine for 15-20 minutes and without reason bogs down to an idle speed. When this happens the red warning light is on and it seems to turn half the motor off. i back off the throttle and wait for a few seconds and im back to normal??? pee hole is steady. not hot to the touch. ive replaced the impeller. I have noticed when running it at home in a tank theres a little spry of water mixed in the the exhaust from the above water port. is that normal? do i have a head gasket failure? should i remove the t-stat and retest? thanks. and it idles forever without a problem.:facepalm:
