Dear friends,
I write from Hungary. I am looking for technical advise. I have problem with the tilt function. I can trim up and down easy. If it is in the top position after few minute it goes down. If i boat it does not hold the motor in the position. I mean it is sealing problem. Do you know, wat should i replace?
Thanks,
Thanks,
