Re: Carb Question on a 1995 suzuki 90 hp
If the nipple is a piece of brass tubing that's pressed into the carb body then I'm fairly confident that you could drill it out and replace with a similar section of brass tubing. Worst case might be a new carb, but I think they're kinda pricey$$. Good Luck!
