windknotnc
- Apr 11, 2004
- 45
I recently put a 1999 200 Yamaha SWII Model #SX200TXRX on my boat and had the carbs cleaned at a local shop to solve a rough idle problem. During this I was told that the middle carb on the engine was not the correct carb. When you look straight at the carbs the throats of the top and bottom carbs appear to be the size of a 1/2 dollar. The middle carb throat is the size of a quarter. Is this correct? I have read that the prime start system enriches the middle carb so I was wondering if that had anything to do with it. Regardless, the engine is still not idling well and sometimes cuts off and sneezes a little then cuts off. It is also rather difficult to start requiring several 5+ second key turns with the key pushed in before it will hit. Any way, if there is any advice or answers to the carb questions it would be greatly appreciated.
