I disconnected the rod going from the carb to the injection pump. I plugged the oil lines going to the manifold. 1.What should I do now? do the wires coming from the oil reserve tank have to be connected for the engine to run? 2.Should I disconnect the tank and remove it? 3.What mixture of oil to run in the tank? 100:1 or 50:1?
