steveinsene
- Jun 25, 2011
- 11
Last time out right before loading the boat the oil light came on and stayed on. Checked oil level the next day and the oil level was slightly above the upper level mark. Am I making oil or what? Does system normally activate when low or what? if anything the level is slightly high. Will probably drain oil and start over with correct level but need to order a gasket first for the drain screw (does this require a special gasket). Also what is a good oil to use? Thanks.
