When I pump up the ball the engine will start but seems to "run out of gas" when the pressure is depleted. I have had tank cleaned, new pick up and fuel line to the new primer ball with integrated anti-siphon valve. Good pressure (when ball pumped) at the output of the fuel separater, inline fuel screen at motor is clean and just replaced the fuel pump. Same situation...starts but stalls when the pressure from the ball drops. If I continue to pump the ball, the engine will continue to run. Driving me crazy!! Help...
