Hi - I have twin 1993 Yamaha 130TXRR motors - 2 strokes. They have served me well the 7 years I have owned them, but have become a difficult to start, and seem to have lost a little of their power at WOT...
So, I set about to try to check all the periodic service settings in the Yamaha shop manual. However, in looking at the timing plate adjustment, the manual states to use a dial gauge in cyl 1 and turn flywheel clockwise to find TDC, then go toward BTDC 3.05mm (I am going counter clockwise here, is that right?), then set the timing plate to 22 degrees. But the plate has limited adjustment, and i'm in the 8-11 range... So I checked the second engine and got the same result. So - I don't know too much about these engines, but assume they would not run properly (if at all) if they were that far out. And the chances of them both being off, by almost exactly the same amount, seem very small, so... Am I misunderstanding the procedure and doing something wrong, or what's could be up here? Thanks!
