I searched but couldn't find an answer for this question so here it is. I have a Glastron boat with a below deck 23 gallon fuel tank and I would like to switch over to an above deck 6 or 12 gallon fuel tank. I thought I'd pick up an atwood or moeller tank and go from there. I'd run the hose from the remote tank to the below deck 10 micron filter and just use the existing fuel line and primer bulb that already run beyond the 10 micron filter to the motor. I believe I need to run 3/8" or maybe it's 5/8" fuel line from tank to 10 micron filter. My questions are is this ok to do with this motor, do I need high pressure fuel injection fuel line from remote tank to 10 micron filter and what size female fitting are usually on the remote tanks?
