Cajun Salt
- Sep 19, 2011
- 2
I have an extra pair of 1998 Yamaha 130 2strokes. They have about 1000 hrs on them and have been well used and well cared for but I have upgraded. I have a guy who may be interested in buying them but he wants compression numbers. I am no mechanic but I want to be sure to give the guy accurate reports. I have borrowed a compression gauge and am charging the boat batteries. Is the correct process to remove all spark plugs and install the compression gauge in one of plug holes then turn the engine over with the starter until the gauge tops out showing me the maximum compression of that cylinder? Then repeat the process for each cylinder? What compression numbers should I expect from these motors if there are no issues?
Thank you
Cajun Salt
Thank you
Cajun Salt
