I recently purchased a boat with a 2003 Yamaha F 80TRLB engine. It has always been difficult to start after not being run for several days. If I run it every day and leave it in the water it will start every morning even if temp is in the 40's .
1. I have replaced all the old gas in the boat as it had been not used often by the previous owner.
2. I have run seafoam and another product suggested by local dealer to clean carbs.
3. I have removed and checked prime start solenoids according to my repair manual and they check out fine.
4. I have sprayed a good carb cleaner on the prime start valve and down into carb where the valves fit.
5. I follow the yamaha recommended starting procedure of leaving throttle closed during start.
Although all of the above has made a difference it still takes 30 seconds or so of cranking to get it to fire and start. Onec it is started and remains in the water it will start every consecutive morning within 2 seconds. I do not want to spend the $700 quoted by the local dealer to overhaul carbs as it does not make sense to me because it runs and starts good at all other times.Anyone got any other ideas ?
