Re: 2001 Yamaha f115tlrz stiff steering
I assume its hard to turn to the right w the motor off?. If so try disconnecting the steering linkage at the engine and turning it by hand, it should rotate smooth and easily. If the steering wheel is stiff to the right when undone from the motor, the problem is there.
