Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
2001 F50 with carbs dies beyond idle
  • 2001 F50 with carbs dies beyond idle
    I have an F50 that idles fine but as soon as I increase rpms it dies. I'm on small island with no good outboard mechanic. Any suggestions? Appreciate any help.
    Re: 2001 F50 with carbs dies beyond idle
    Check compression, spark, and timing to make sure motor is still in good shape.
    Most likely you have a carb /fuel problem and need to pull and clean.
    A Yamaha service manual will go a long way helping you do your own maintenance, but you will need some tools and equipment the normal guy does not keep around the house
    • #3
      Commander,
      Thanks for the advice.
      • #4
        Check inline/water separating filters/kinked lines/vent line or vent valve if a remote tank. also if you just recently replaced the water separating fuel filter be sure you are using the correct one. got bit once by installing a 1o micron filter not the 6-8 that was original, resulted in same issue.
        Back to Top
