Hi There.
Long time listener, first time caller.
A friend of mine has a 1992 115 HP Yamaha V4 (2-cycle) Outboard that has cold starting issues. Here are the quick details:
Turns over OK. Electrical appears OK. Spark on all cylinders. Just won't fire. The problem is intermittent.
What I am noticing is that there appears to be a large fuel slick behind the boat after even moderate amounts of cranking. This has been an ongoing intermittent problem for my buddy.Sometimes he has no issues cold starting and other times it seems to be impossible to get it to fire. He has had the CDI unit changed as it was determined last year that this may have been part of the problem. I personally think there is a underlying problem we just aren't seeing.
When the motor does start and run it runs flawlessly. No misfires or skips. This is a 2-cycle that is NOT oil injected.
I can tell you anything else you need to know to perhaps help diagnose. I'm just wondering if anyone else out there has seen this problem or something like it.
Thanks!!
Thanks!!
