My engine feels like it is running on 2 of my 3 cylinders. While on the river, I used my timing light and all three cylinders were firing. I then looked around the engine and saw a bunch of gasoline coming from a port in the side of my #1 carb! It was a steady stream, and more than a trickle. Any ideas on what it is? I cleaned my carbs about 1 month ago. I don't think that port is supposed to be plugged because there are no threads on it. I didn't notice any gasoline coming from the other carbs. When I go to full throttle, I get no power at all, 3000 RPM and about 8 mph. At idle, it wants to stall really bad. The engine was running fine the 3 times I used it after cleaning the carbs (would start on the first crank). Now it takes a bunch of work to start it.
