citadel1995
- May 2, 2010
- 22
I have a 96 Yamaha Saltwater series 150hp. Was running great, shifting with no problems. Was going about 4500rpms when canopy railing flew up & snapped so I pulled throttle back fast, when everything was tied back down I gave it gas and the motor went into gear but when I hit throttle the motor revs up but the prop starts slipping. The motor goes into forward & Reverse with no problem, and as long as it stays under 1200-1500 rpms the prop spins and works as usual. but once more throttle is given the motor revs up but nothing from the prop. I got home, and with the motor off put it in gear and tried to spin the prop by hand and applying some force it turns the drive shaft and motor with no slip, in both forward & reverse. I drained the lower unit and the oil was milky (I changed it this year) and there were some metal shaving on the drain plug magnet. Any advise on what I should check or do first? How can I tell if it the prop Hub or the gears with out taking it all apart?
Thanks for any help!!
