Re: 89 Suzuki DT 75 oil leak
Quite common. Are you using the Suzuki oiling system. If you are you could be running with a carb or carbs that need servicing and restricting the fuel flow. I other words running on an oil rich mixture. If you are running on 50:1 the carbs could be flooding or incorrectly set causing a Rich mixture. If the plugs are grungy the oil is not burning off. A cold motor, perhaps the thermostat has been removed, will have the oily symptom. A lot of idling will also produce the symptom. There is adjustment in the pump link rod which can be used to set the oil flow. This must be done in accordance with the set up procedure in the manual.
Hope this is helpful.
