I need a top cowling for a 2006 50 hp yamaha
sbarrera4
Does the cowling have to be from the same year? The cowling flew off during transporting the boat. The Outboard is a 2006, 50 hp 2 stroke Yamaha, does anyone know about what other models (year) will fit my outboard. Thanks for your help.
robert graham
Re: I need a top cowling for a 2006 50 hp yamaha
If you had any idea where it flew off you might go find it on the side of the road?
luckyjim17
It appears that the requester may have thought of looking for the cowling. It may have been a lengthy transport as well as there is a good chance the cowling is damaged. EDIT: quite rude.
gstrom11
Wow, good luck, check Ebay, etc... found one on this site for over $500.. Yikes
Nevermind, that's just for the cowl, none of the other stuff, way more than $500 total then.
robert graham
Quite to the contrary, maybe it never occurred to the guy to just backtrack his route and look for it, and since the cowlings are fairly light but strong plastic/fiberglass, it may be in the ditch or median, undamaged. It was just an idea.
sbarrera4
I did go back that same night and the next morning all the way to the state park and inquired at the ranger station.
sbarrera4
I did go looking for it but no luck. I now need to get one however I am interested in knowing what other model year will also fit mine so I can look for a used one. Thanks.
sbarrera4
They are costly, hope I can find a reasonable priced used one. Thanks
sbarrera4
I wish I had found it but no luck. Damaged or not It would have been great but no cigar.
sbarrera4
Yeah, I have the cowling is quite expensive I am searching for a used one I just need to find out what other model years also fit. Thanks
robert graham
Well, I know the new cowls are awfully expensive, but maybe check around some local boat dealers and maybe they have one off an old motor? Don't you hate stuff like this...just a lot of time, money and aggravation! Good Luck finding one!
99yam40
Did you look at the parts web site like I said? It shows which years and models fit
99yam40
I believe that one is from a 1993 model not 2002 and above like the link shows
sbarrera4
Yeah it is aggravating, I posted fliers around the area and have been checking flea markets, and boat shops. Well... If I can't find one I can afford I guess I am going to have to make a homemade one. Thanks.
sbarrera4
Yeah it is a '93 according to the listing it won't fit.
These are the ones that fit
2002 40TLRA TOP COWLING
2002 50TLRA TOP COWLING
2003 40TLRB TOP COWLING
2003 50TLRB TOP COWLING
2004 40TLRC TOP COWLING
2004 50TLRC TOP COWLING
2005 40TLRD TOP COWLING
2005 50TLRD TOP COWLING
2006 and Later 2-stroke 40TLR TOP COWLING
2006 and Later 2-stroke 50TLR TOP COWLING
I wonder what the difference is maybe it can be slightly modified to fit?
sbarrera4
yes it is, I wish I knew the differences, maybe it can be slightly modified to fit.
