Engine runs good at idle once warmed up. Going down the canal it has a pop at 14 to 18 rpms will stop for about a min the start again. Once I get out and up to speed slight hesitation out of the hole. If I come up on the throttle slow it will work right past the hesitation. All happens under 2600 rpms been like this for two seasons replaced filters synced carbs cleaned carbs replaced fuel pump fuel lines all gaskets in fuel system same symptom.
Any ideas sounds like a lean pop sync gauge drops on one carb when the pop happens.
