Suzuki DF6 Cooling Problem
dougneve
I have a Suzuki DF6 6hp 4-stroke outboard, which is about 4-years old and has had little use. I recently ran the engine, however there was only a slight discharge from the pilot water hole. The engine has been used in salt-water, however the cooling system is always flushed after running.
I would appreciate advice on how to solve this problem.
Doug Neve
