StamfordRob
- Mar 12, 2010
- 9
All.
I just put my boat in the water and ran it WOT and it hit 3600 then quickly leveled off below 2000 rpm. It died at one point as well but I am able to putter around at half throttle. I checked the primer ball and it gets hard when pumped and stays there. The rest of the lines are new including the tank.
I also ran on a portable tank and it happened the same way. I was told that they high end jets are clogged. I see from diagrams that I have the Main Jets looking right at me when the cover is off. Are these the same jets? If so can i clean them w/o removing the carbs. At this point I'd rather clean them best I can and operate on the carbs this November. I had a late start with the new tank going in.
Thanks in advance.
Rob
Thanks in advance.
Rob
