Hi Folks,
I have a 98 tracker 4 stoke 50 hp (made by mercury) , yamaha power head
the motor had a really rough idle so I cleaned the carbs and fixed that issue
the motor will race up to over 2k at idle when I put it in neutral after running it
a little bit or alot it does it all the time . I've check the carbs and controls nothing is binding etc. I also checked the compression 150 + in all 4 and I checked timing due to the motor had the head repaired at one time so I let it run and put it in nuetral and the timing went from around zero ish to 25 + degree's advanced like wot timing so the only ting I can figure is teh CDI is messed up but I figured I would ask for some input. thanks in advance
