Hi,
Tried to figure out how to overcome this issue: the side oil tank does not fill up anymore. This puts the engine on security. I checked the main oil tank, the pump of the main oil tank too they are fine. Only way to fill it up is manually by turning the key on but not starting the engine then there is a switch on the engine itself which allow this small tank to be filled up. I
Is it possible this comes from the CDI this is a suggestion of my dealer but before engaging into this repair (quite expensive indeed) i would like to receive a third party opinion...
Many thanks in advance!
