MaineFishin
- Jun 23, 2011
- 41
Folks,
1989 Excel. Here I go again; I removed the lower unit and have all the snapped bolts out. I decided to start the impella replacement, I removed the four bolts fastening the housing and removed the housing. Removed the metal dome and the impella is sitting there. On top of the impella is a small cap with a gasket and several washers, this piece did not want to budge. I pryed under the impella and was able to have it move up the shaft but the gasket under the cap disentegrated. WHAT IS this piece, it did not come with the impella kit.
On the bottom under the keyway is a metal plate, under this plate is a gasket that is in my kit but I am unable to get the metal plate past the keyway, any ideas.
Thanks for your advice, I expect it will take a minute or two for you to stop your laughter, I am shaking my head at myself!
