Hi, hoping someone on here can steer me in the right direction cause I'm out of ideas. History:
2 stroke, oil injection, mdl P60TLHU.
I've owned this engine for @8 years now and the only problem I have had was the neutral position switch failed open and I thought it was the ignition (**** poor troubleshooting on my behalf on the water that day)
On the way back to the boat ramp a few days ago at WOT. All is good then all of a sudden it bogs down like I had hit a large patch of millfoil. Shut down, in reverse to clear prop, back in business right? Not this time. At WOT it wont get anymore than @1100 rpm. When I used to get 2700 rpm and 35mph. Nothing overheating, no buzzers (I have had the over temp buzzer go off when setting decoys once and the RPM's were limited until it reset/cooled off) But strange enough if I trim it all the way into the water I can get up to 1400 RPM's. Idles rough as well. The RPM's actually go up and down with the motor trimming up and down. Without touching the throttle.
Changed out plugs, no change. Runs fine up to max RPMs with muffs in the driveway. But put it in the water and it bopgs out. Good fuel. Checked fuel filter, it was clean.
Any help would be great.
