stovebolt62
- Apr 7, 2009
- 4
Hello, have a 93 Yamaha 3 HP 2 stroke. Motor was not running right, so I took carb completely apart and cleaned it, bought and installed a carb kit, replaced the spark plug, put it all back together and motor still bogs down under throttle. Eventually it will flood out and not start. The fuel is getting to the carb as I took fuel hose off and checked the flow from tank. I was thinking it could be the carb to manifold gasket was not sealing right as I did not replace this. Other than that, I'm at a loss. I have alot into this motor as I also changed out all the water pump components and would like to get this running right. Any help would be appreciated.
