2001 tlrz yamaha 4 stroke I have changed hp pump, filters in vst ,cartridge filter, plugs and just had injectors cleaned. The motor bogs down afteer a few seconds of wot,which ive heard in previous post so im telling you what i have done and seeing if I can check anything else prior to taking it to a dealer.The motor idles fine and runs good except after you get to wot for a few seconds or4500 5000 rpm ,I can run good at 30 miles an hour with no trim just fine .However i can trim it to about 40 miles an hour but the boat used to run 50 .17 foot seapro center console. seems like im losing fuel when it bogs down.It does bog down and sometimes I will shutoff the engine and then restart and it will take right off again. the hp pump went out thats why i replaced.Sometimes I will have to shut off the motor and back on to get it running right.
