2003 70 Hp Yamaha will stall out when advancing throttle.All carbs were removed soaked in carb cleaner washed and blown dry with new kits.Compression is 124 lbs on all cylinders with good spark and fuel.I noticed if i hold my hand over the intake of carbs 2 and 3 there is very little suction and has little effect on how the engine runs.If I hold my hand over cylinder 1 it will stall out the motor. Also if i pull the wires off of cyl 2&3 it has little effect on how the motor runs. I also noticed that sometimes if i punch the throttle repeately the motor will take off and run fine at 5500-6000 rpm w.o.t untill i shut it down and try to restart it. Hope you can help,it's driving me nuts.Thanks for your help
Tom
Tom
