yamaha f225 powerhead removal
robaloroger
2004 f225 I am removing the powerhead and it seems a little stuck. Are there any tricks to pry the head off without damaging anything. I am pretty sure I removed all the bolts. Thanks in advance
Re: yamaha f225 powerhead removal
You could partially put in one of the PH bolts and use a bottle jack put on the anti vent plate and use a dowel to to push up on the bolt.
