I have a 1998 Yamaha 150 saltwater II series outboard that I recently (2 weeks) changed the gear oil in with no problems. Took the boat to the water this weekend and it performed well. After clean up and parking of the boat, the lower unit is leaking gear oil by the prop (not by either plug for changing the oil). It only leaks when the motor is fully lowered. When I put a slight trim on the motor, the gear oil does not come out. There does not appear to be any water in the gear oil (it has the same smell, texture, and color as when I replaced it). Any help is greatly appreciated.
