Re: Suzuki DT85 stalls when in gear
Ok, this seems like a simple problem to figure out the answer to, but for some reason the "trained" mechanics can?t come up with a solution. every time I ask a shop I get a response like: well it could be dirty carbs, or something wrong in your shifter, or compression, or water pump, plugs, fuel pump.......they list every component in the engine and then say you will have to bring it in for us to look at it, our shop rate is $195.00hr with a 2hr min. LIKE HELL, I don?t know about you but I am on a very tight budget and $195x2 without a guarantee that it will be fixed isn't happening, this is so frustrating! I did a lot of research and looking over my engine and I think I found/fixed the problem. On the right side of the engine just below the flywheel there is a fixed metal piece that doesn't move and the linkage comes up vertical to that point. Sorry I don't know the name of the part! Follow the linkage up vertical to this point and you will see that that part can pivot and has a bolt going through it that will touch that fixed metal piece (stopper). I noticed that there was a space between the bolt head on the linkage side where the bolt head wasn't touching anything and on the other end of the bolt the nut wasn't touching anything as well. You screw the bolt in or out to make adjustments and when you get it where you want it the nut is tightened down to hold it firmly in place. The way mine was there was about a cm of play that the bolt could vibrate in and out changing the adjustment on the motor. No wonder why it wouldn't idle right! I had the ears hooked up and the motor on and pushed that linkage forward a little and you could hear a difference in RPM. I then filled up a tub of water and lowered the lower unit in it to run as it would in the water with a little backpressure and made the adjustment and tightened the nut down real tight. This made all the difference in the world! The engine runs a lot smoother without twitching and vibrating all over; it sounds strong, and runs great at idle. I put it in gear for a few seconds and there was no CLUNK noise, it shifted smoothly and best of all IT DIDN'T DIE WHEN I SHIFTED BACK TO NEUTRAL!!!!! 1987 85DT runs like a new engine now. Hope this helps with what sounds like the same problem, I know we have all been chasing this ghost for a while
