Can anyone help? My DT65 has lost full power. I Initially thought a fuel blockage so clean carbs but they were clean. Then I checked the fuel diagphram which had perished. This was replaced. The start up was fine and seemed to tick over better ie all 3 cylinders. I took it out for an open water test and I still can only manage 13knots on an alaska 500. Before I was managing 26 to 28knts full throttle. Fuel consumption has over doubled. Impellor has been replaced yet still has temperamental output. There is no wax thermostat in the housing so should pump consistently.
What should I check next.? There is spark on all three plugs. It feels like fuel starvation.
Thanks Allan
Thanks Allan
