Re: 1990 yamaha 70 h lost forward gear only reverse working?
its a real pain to get off. I had the reverse gear and clutch dog go on mine years ago. You usually have to heat the gear case to loosen it up and then use a puller. I would suggest having someone thats done it a few times before do it for you or you could ruin the whole lower unit.
